Possible zu use existing nvme hat?
hi,
I am currently running my home assistant server on a raspi5 with pie and nvme.ssd hat (geekworm) … works perfect BUT cooling is an issue so I would love to get a pironmen kit …
  • can I use my geekworm name hat I stead of the pironmen ?
thanx and greetz from Vienna
c
If you only need the heatsink in the pironman5 kit to work with your parts that is fine.
However, if you want to realize the function of pironman5, you need to install our pironman5 hardware, with the installation of our pironman5 software, the function can be realized properly.
Maybe I didn’t understand your question, please explain your needs in detail, provide more information to us, pictures or videos, so that we can understand your problem more intuitively.
hi,
have a raspi5 with:
  • POE HAt on top
  • Geekworm X1002 M.2 NVMe SSD Pip PCIe Peripheral Board Bottom for Raspberry Pi 5
running a home assistant server
what i am asking for is:
can i run this setup as it is with the pironmen case ?
cheerz
It is not compatible to install POE HAt in pironman5 chassis because the structure is different and there is not enough space for you to install it.
Regarding whether POE HAt is compatible to work with pironman5, I’m very sorry, we haven’t verified it against tests and can’t answer your question.
In another thread, there is a user working on a similar project to yours, you can go and discuss it with each other.
