Pironman5 installation error on RPi5
Need help. Got error while installing Pironman5
Details
When installing pironman5 from GitHub I get error failed to build installable wheels for some project.toml while installin pironman5
Then when I try to check the status of pironman5.service got message pironman5.services: failed with result ‘exit-code’
I followed the instructions
cd ~
git clone -b 1.2.15 https://github.com/sunfounder/pironman5.git --depth 1
cd ~/pironman5
What system are you currently using? What is the system version?
Did you execute or install anything else before installing the pironman5 software? Please tell us the steps you took so we can assist you in analyzing and resolving the issue.
Are you encountering an error when installing the pironman5 software? Please provide the complete error message so we can help you analyze and resolve the issue.
Got it fix. I installed first OPENMEDIAVAULT which also installed python3 packages, after a couple of tries I installed pironman5 first and then OMV and it works. Recommend that in the instructions it should be noted to install pironman5 first then OMV, I just followed the online instructions.
Thanks for your reply
Mike
Is your product the Pironman5 Max?
If it’s the Pironman5 case, we do not recommend installing OMV, as setting up RAID requires at least two disks, and the Pironman5 case only has one NVMe slot, so you can only connect one SSD.
If you have the Pironman5 Max, you can install OMV first and then install our Pironman5 software; theoretically, it should install successfully. Our tutorial sequence is to install OMV first and then the Pironman5 software, which works fine.
Before installing OMV, did you install anything else or perform any extra operations? Please let us know so we can help you analyze and resolve the issue.
It is a pironman5 Max
installing OMV first and then pironman5 did not work. As pironman5 tries to install python3 which was already installed by OMV7. Notice error on python3 install and error on pironman5 install. I used a RPi5 running the lite version of RPI image
Again solved the issue by installing Pironman5 and then OMV7
We have reproduced the issue you encountered, and it is not related to the installation order. The problem arises because if you install OMV before the Pironman5 software, it will cause the python3-dev library to be missing. When you then try to install our Pironman5 software, some libraries will fail to install.
We have updated the Pironman5 software, and this version addresses the installation failure issue. We have also modified the installation instructions in our online tutorial. Please see the tutorial link:
https://docs.sunfounder.com/projects/pironman5/en/latest/pironman5_max/set_up/set_up_rpi_os.html#downloading-and-installing-the-pironman5-module
Installation commands:
cd ~
git clone -b max https://github.com/sunfounder/pironman5.git --depth 1
cd ~/pironman5
