in the description is a vibration sensor listed:
Features — SunFounder Pironman 5 documentation
But on the board is no jumper for the sensor like on the max version.
Does the Pro Max really had this vibration sensor?
The Pro Max does not have a vibration switch. The OLED display is activated by briefly pressing the power button.
I patched it so it always stays on. Nothing worked on my install. Claude Code saved the day.
The Pro Max does not have a vibration switch. Briefly pressing the power button will activate the OLED display. You can modify the OLED sleep time using the command:
sudo pironman5 -os 30
(post deleted by author)
