Can anyone suggest an RGB LED that would be compatible adding to the PiCarX RobotHat that includes cabling and instructions. My goal is to add an RGB LED to the PiCarX and be able to turn it on and off using the Robot Hat.RGB_LED.write() programming interface from python. Is this possible and if so, is there a product you would recommend? thanks!
This one uses a common-positive RGB LED and connects the RGB 3 pins to the PWM interface for use.
