Hi. I bought a PiPower 3. So fair so good - however, I can Not find and Information about the pinnen of the „Pin Headers for RPi“. Easy question: which signal is on which pin?
I am asking because I want to operate on my PiPower 3 the Solution acc. Raspberry Pi UPS Power Bank - Monitor Battery on Blynk (they use it on the previous PiPower Version).
Regards from Andreas
Please review the tutorial instructions here:
Pipower 3 Quick User Guide
Key Improvement in Pipower 3:
Unlike Pipower V2 which required manual pin detection wiring, Pipower 3 comes pre-connected to the Raspberry Pi’s GPIO pins. This means:
- No manual wiring needed for pin detection
- Simply install our Pipower 3 software to get started
Hello und thanks for your reply
I’ll follow what you recommended - that is the easy way to go which is acc my first idea.
However, there is a software solution defined for the v2 of the PiPower and therefore I am looking for a comparison - are the signals defined for version 2 also available for version 3?
Best regards
Andreas
I received the following reply from SunFounder‘s Support:
Thank you
