Snow on my Oled dislpay with new pironman / raspberry pi 5 setup
So I just assembled my pironman case together with my new raspberry pi 5 and installed the pironman software on my raspberry. sadly enough I encounter the following problems:
  • Oled display shows snowy screen (like old tv)
  • No oled light at all
  • 2 Back fans never spin at all.
  • Cant access any web page for configuration on the 34001 port.
Got the following errors in my log:
pironman version: 1.6.2
Kernel Version:
Linux raspberrypi 6.12.48-v8-16k+ #1905 SMP PREEMPT Mon Sep 22 13:35:50 BST 2025 aarch64 GNU/Linux
OS Version:
Description: Debian GNU/Linux 12 (bookworm)
PCB info:
Revision : e04171
Model : Raspberry Pi 5 Model B Rev 1.1
25/09/24 09:25:18,221 [DEBUG] power_key_pin : 16
25/09/24 09:25:18,221 [DEBUG] fan_pin : 6
25/09/24 09:25:18,221 [DEBUG] rgb_pin : 12
25/09/24 09:25:18,221 [DEBUG] update_frequency : 0.5
25/09/24 09:25:18,221 [DEBUG] temp_unit : C
25/09/24 09:25:18,221 [DEBUG] fan_temp : 50.0
25/09/24 09:25:18,221 [DEBUG] screen_always_on : False
25/09/24 09:25:18,221 [DEBUG] screen_off_time : 60
25/09/24 09:25:18,222 [DEBUG] rgb_switch: True
25/09/24 09:25:18,222 [DEBUG] rgb_blink_speed : 50
25/09/24 09:25:18,222 [DEBUG] rgb_pwm_freq : 1000
25/09/24 09:25:18,222 [DEBUG] rgb_color : 0a1aff
25/09/24 09:25:18,248 [DEBUG] rgb_strip init failed:
ws2811_init failed with code -3 (Hardware revision is not supported)
25/09/24 09:25:18,248 [DEBUG] error
25/09/24 09:25:18,248 [DEBUG] name ‘strip’ is not defined
does this mean the pi 5 model is still too new to use pironman case on ?
Did you install the right version for your pironman5? There’s 3 variants, the standard, the mini and the Max. After that, can you provide a screen shot or video when you install pironman5 software?
Thx man! seems I took the pironman instead of pironman5 :pensive_face: .
Even with pironman5 you have 3 différents models: standard, mini, max.
