Troubleshoot "syntax error in JSON"
I have pico 4 wd kit but when I try to control using app… after copying app_control program as main.py and while it’s running I get this error. syntax error in JSON
kit url -
https://docs.sunfounder.com/projects/pico-4wd-car/en/latest/
I’m not sure if it can help you, I took a quick look at code and I think I found a mistake in AP wifi setting for SSID, as shown on pic. Maybe try to set SSID “pico_4wd_car” and upload code through car.
thanks for the response ! Tinkered program a bit to capture jason being sent from the app to WS. this is the log. it’s consistently missing K value. any ideas ? I am using sunfounder controller app on iphone 16 and used pico4wd layout
ws loop, receive: {“”:null,“A”:0,“Len”:“0028”}
on revceive: {“”:null,“A”:0,“Len”:“0028”}
Raw Data Received: {‘A’: 0, ‘’: None, ‘Len’: ‘0028’}
Received Data: {‘A’: 0, ‘’: None, ‘Len’: ‘0028’}
Warning: Missing ‘K’ key in received data.
Try pressing the app’s k control (directional control rocker) all the time and see if it works.
I tried a few options but did not work… can you send me what is the exact file format this webserver expects to receive? I checked all documentations online - but could not find this. I guess there may be a few format for direction controls, start stop… adding those to documentation may help many others like me too. Thanks for your reply.
Normally, you will receive data similar to the one shown below.
