Tried to install picar-x with the following according to https://docs.sunfounder.com/projects/picar-x-v20/en/latest/python/python_start/install_all_modules.html:
cd ~/
git clone -b v2.0 GitHub - sunfounder/picar-x
cd picar-x
sudo python3 setup.py install
Received the following errors:
File “/home/username/picar-x/setup.py”, line 17, in
setup(
File “/usr/lib/python3/dist-packages/setuptools/init.py”, line 107, in setup
_install_setup_requires(attrs)
File “/usr/lib/python3/dist-packages/setuptools/init.py”, line 75, in _install_setup_requires
dist = MinimalDistribution(attrs)
File “/usr/lib/python3/dist-packages/setuptools/init.py”, line 57, in init
super().init(filtered)
File “/usr/lib/python3/dist-packages/setuptools/dist.py”, line 473, in init
for ep in metadata.entry_points(group=‘distutils.setup_keywords’):
File “/usr/lib/python3.11/importlib/metadata/init.py”, line 1040, in entry_points
return SelectableGroups.load(eps).select(**params)
File “/usr/lib/python3.11/importlib/metadata/init.py”, line 476, in load
ordered = sorted(eps, key=by_group)
File “/usr/lib/python3.11/importlib/metadata/init.py”, line 1037, in
eps = itertools.chain.from_iterable(
File “/usr/lib/python3.11/importlib/metadata/_itertools.py”, line 16, in unique_everseen
k = key(element)
File “/usr/lib/python3.11/importlib/metadata/init.py”, line 954, in _normalized_name
or super().normalized_name
File “/usr/lib/python3.11/importlib/metadata/init.py”, line 627, in normalized_name
return Prepared.normalize(self.name)
File “/usr/lib/python3.11/importlib/metadata/init.py”, line 882, in normalize
return re.sub(r"[-.]+", “-”, name).lower().replace(‘-’, '')
File “/usr/lib/python3.11/re/init.py”, line 185, in sub
return _compile(pattern, flags).sub(repl, string, count)
TypeError: expected string or bytes-like object, got ‘NoneType’
I am using Raspberry Pi 4 with the following OS:
Linux raspberrypi 6.6.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.20-1+rpt1 (2024-03-07) aarch64 GNU/Linux
I was unsure if the issue was related to python version, so I tried using python3.10.14 (installed via Pyenv) but the same issue persisted. For some reason, some of the functions in setuptools still continued using the system’s python (3.11) despite the python version set to 3.10.14 with pyenv.
Any idea how to solve this issue?
