I got the following errors as I ran the install_dependencies script (command entered: sudo ./install_dependencies). All other applications appeared to install. jpeg attached shows the results of the script. Please advise how to proceed.
Thank you,
Lori Pfahler
The version of Raspberry Pi you are using is bookworm.
Sorry, but picar-v is not compatible with bookworm, so we recommend you to use legacy version.
Thank you for the response. I was able to get the install script to work with an earlier version of the RPi OS. I would suggest updating the on-line manual to reflect this.
Kind Regards,
Lori Pfahler
Yes, we will update the documentation as soon as possible, thanks for your feedback.
