I ordered my PiCar-X several monthes ago and received V1.
Assembly is done and was a great experience with my son but following the " Install All the Modules" part of the documentation lead to an error installing vilib
Installed OS: raspiOS legacy with rpi-imager
SSH access is OK, camera is functionnal with another SD-card installed with EZblock
pi@raspberrypi:~ $ git clone -b picamera2 https://github.com/sunfounder/vilib.git
Cloning into 'vilib'...
remote: Enumerating objects: 798, done.
remote: Counting objects: 100% (259/259), done.
remote: Compressing objects: 100% (134/134), done.
remote: Total 798 (delta 154), reused 181 (delta 109), pack-reused 539 (from 1)
Receiving objects: 100% (798/798), 32.23 MiB | 11.30 MiB/s, done.
Resolving deltas: 100% (455/455), done.
pi@raspberrypi:~ $ cd vilib/
pi@raspberrypi:~/vilib $ sudo python3 install.py
Start installing vilib 0.3.16 for user pi
Python version: 3.9.2
Raspbian version: 11 (32bit)
mediapipe is only supported on 64bit system.
Install vilib python package
- pip3 install ./ ... Done
- cleanup ... Done
apt install dependency:
- dpkg configure ... Done
- update apt-get ... Done
- install python3-libcamera ... Done
- install python3-picamera2 ... Done
- install rpicam-apps ... Error
- install python3-pyqt5 ... Done
- install python3-opengl ... Done
- install python3-opencv ... Done
- install opencv-data ... Done
- install ffmpeg ... Done
- install libgtk-3-0 ... Done
- install libxcb-shm0 ... Done
- install libcdio-paranoia-dev ... Done
- install libsdl2-2.0-0 ... Done
- install libxv1 ... Done
- install libtheora0 ... Done
- install libva-drm2 ... Done
- install libva-x11-2 ... Done
- install libvdpau1 ... Done
- install libharfbuzz0b ... Done
- install libbluray2 ... Done
- install libatlas-base-dev ... Done
- install libhdf5-103 ... Done
- install libzbar0 ... Done
- install libopenblas-dev ... Done
pip3 install dependency:
pip3 install with --break-system-packages
- update pip3 ... Done
- install tflite-runtime ... Done
- install Flask ... Done
- install imutils ... Done
- install qrcode ... Done
- install pyzbar ... Done
- install pyzbar[scripts] ... Done
- install readchar ... Done
- install protobuf>=3.20.0 ... Done
- install numpy==1.26.4 ... Done
mediapipe is not supported on this platform... Skip
Create workspace
- create dir ... Done
- copy workspace ... Done
install rpicam-apps error:
Status:100
Error:Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package rpicam-apps
rpicam-apps seams to not be available to install, libcamera-hello is present and functionnal.
Can you help us ?
