Zeus car will not initialize
After initial build Zeus was inconsistent in terms of initializing. Took many successive resets to get blue lights to come on. Once initialized Zeus worked fine for several weeks. Now it will not initialize at all. On reset the RGB strips simply flash green once and nothing. I hooked up the USB blue cable used for downloading, and went int the IDE serial monitor. I can see that the IR and Ultrasonic functions are working. Just no blue lights or motor function after reset.
Any debugging advice?
It is recommended that you re-upload Zeus_Car.ino to the Arduino board. The file path is: zeus-car-main\Zeus_Car.
After the code file is successfully uploaded, please do not disconnect the USB data cable. Open the serial monitor and check the printed information.
Once the code is successfully uploaded, you need to slide the smaller switch to the right to establish communication between the car and the ESP32 CAM. Then, press the “Reset” button to reboot the code. At this point, you will observe the undercarriage lights transition from orange to light blue.
https://docs.sunfounder.com/projects/zeus-car/en/latest/get_started/app_control.html
If possible, please record the process video for us to analyze and solve the problem.
Sorry I took so long to respond.
Your advice worked 100% so thank you for that. The Zeus not only came back to life, it solved the intermittent reset issues we had from day 1.
Thank you again.
Has anyone had success doing this? I am struggling to get this uploaded without errors
Yes, the Zeus Car code can definitely be uploaded successfully — most users get it working on the first try. If you keep getting errors, it is usually not a hardware problem with the car, but a local Arduino IDE configuration issue (libraries, board selection, port, or driver). We can sort this out together.
To pinpoint the cause as quickly as possible, please do one thing first:
Send us the full error message — either the error text or a screenshot (please include the error window and the bottom status bar of the Arduino IDE). This is the key to diagnosing the issue, and with it we can usually tell you the exact cause and fix right away.
In the meantime, please double-check these three points (this is where the problem often lies):
Is the board selected as Arduino Uno?
Is the Port set to the one the car is actually connected to?
Have you installed all the required libraries as described in the tutorial?
Official upload steps (including library installation):
Once the upload succeeds, please proceed in this order:
Keep the USB cable connected, open the Serial Monitor, set the baud rate to 115200, and check the output;
Move the small switch on the car to the right to establish communication between the car and the ESP32 CAM;
Press the Reset button to restart the code. The chassis indicator light should change from orange to light blue.
If convenient, please also let us know your operating system (Windows/macOS/Linux) and Arduino IDE version, so we can give you more specific steps.
Once we receive the error message, we will analyze it and get back to you with the next steps as soon as possible. Thank you for your cooperation!
