I’m having trouble getting the 3.5-inch LCD touch screen working with my Pironman 5 setup. I followed the official tutorial at https://docs.sunfounder.com/ step by step but the screen is still not working.
Hardware:
- Raspberry Pi 5 Model B Rev 1.1
- Pironman 5 case
- 3.5" TFT LCD Touch Screen (ILI9486 driver IC, 480x320, resistive touch, XPT2046 controller)
Software:
- Raspberry Pi OS 64-bit (Debian GNU/Linux 13 Trixie)
- Kernel: 6.12.47+rpt-rpi-2712
- pironman5 service v1.2.15
What I did following the tutorial:
- Removed the RGB jumper on the IO Expander as instructed
- Disabled RGB LED service:
sudo pironman5 -re false+ restarted service - Cloned and ran LCD-show:
sudo ./MHS35-show— installed successfully, fb_ili9486 driver loaded correctly dmesgconfirms:fb_ili9486 frame buffer, 480x320, spi0.0 at 115 MHzandfb0created
The problem:
The screen stays completely white — no image at all. Writing random data directly to /dev/fb0 with cat /dev/urandom > /dev/fb0 produces no visible change on the screen. The desktop works fine on HDMI but never appears on the 3.5" screen.
Question:
Is there a known issue with this setup on Raspberry Pi OS Trixie (Debian 13)? Is there a specific configuration needed to route the display to fb0 on Pi 5?
Thank you!
