Hi, (I apologize for my English, but it’s not my main language)as the title says, I just can’t access pironman 5 website. I need control over the fans at least, the commands don’t work for some reason. The link is http/ :3080 and when I try to search it, only results are some IP tracking websites, what could cause it ?? I installed pironman os already.
Hi, to begin, which OS are you using? Have you install the right software for Pironman5? Set Up on Raspberry Pi/Ubuntu/Kali/Homebridge OS — SunFounder Pironman 5 documentation
To access to dashboard, you need to find the IP of your raspberry Pi 5 and add :34001 as mentioned there : 5. Control with Commands or Dashboard — SunFounder Pironman 5 documentation
Also you can control Pironman5 settings through terminal.
I hope my English is good enough for you. I’m better in French ![]()
Forgive my Linux ignorance, to access the control panel for Pironman 5 we have to have specific OS installed. This can not be accessed with the standard Raspberry Pi OS?
You need to install a compatible OS, check list. And then install Pironman5 software.
https://docs.sunfounder.com/projects/pironman5/en/latest/
The instructions are well done.
If you have any questions, feel free!
