Hello, I just finished setting up my Pironman 5 kit but when I try to go to the dash from a browser the page is blank. The only thing I can do is switch to dark mode
Did you update the OS? sudo apt-get update && sudo apt full-upgrade -y
And update the kernel sudo rpi-update
Then sudo reboot
Thank you for the response. It’s still comes up blank though ![]()
You’ve installed the lastest version of Pironman5 software? Which OS are you using?
I’m running Pi OS. I’ve copy pasted the script to update a few times: it always says there are 0 things to update and 0 things were added
You even install Pironman5 software with those commands?
cd ~
git clone GitHub - sunfounder/pironman5: Code for Raspberry Pi 5 case (Pironman5)
cd ~/pironman5
Yes. I think I installed it right. The OLED, 4 LEDs and CPU fan are working but the two fans with the RGBs have not turned on and the dashboard is blank.
Can you take a picture of the log file?
cat /opt/pironman5/log
sudo systemctl status pironman5.service
It seems that the dashbord is not working if you are using “localhost” or “127.0.0.1”.
You should use your IP adresse.
Do I enter “localhost:number that comes up on the OLED screen”?
You should enter the numbers from the OLED screen then “:34001”
For exemple, 192.168.1.250:34001
Yep that was it. Thanks your help!
