I’ve just assembled my Pironman 5 Max. I’m new to raspberry pi.
The gpu fan is working, the case fan are not I’m yet to set up the OS I don’t know if that make any difference, I have 2 green lights visible, one at the front the other at the back of the unit.
I did have some difficulty screwing the fans to the case they were hard to do, I don’t know if that is related. I didn’t use rhr jumpers I didn’t see that on the instructions or a video I watched on YouTube.
I don’t see any RGB lights either!
The button doesn’t turn the unit off is that because I’ve not got the storage installed yet?
Is there anything else I should be installing when I sort out the OS?
If you have not installed the Pironman5 software on your system, the RGB fan will not work.
You must install our Pironman5 software for all functions of the case to operate normally.
It does require a bit of force to screw the fan in place. Are you able to tighten the screws properly?
Are the RGB lighting effects completely absent?
This is because you have not installed the Pironman5 software, which is why the RGB lights are not functioning.
Please follow the tutorial steps to install the Pironman5 software: [Installation Guide]
Is the power button unable to turn off the device?
What system are you currently using?
If you are using a Raspberry Pi system with a desktop, you can shut it down by pressing the power button twice quickly, or by holding the power button for 5 seconds. Pressing the power button once more will turn the system back on.
Please check if the pins of the power adapter are aligned and in good contact with the PI5 pins.
Also, ensure that the pins inside the adapter’s socket are properly aligned with the power button connector.
You can unplug the power button wiring, power the system on, and then use a screwdriver to short the adapter’s interface to see if it can shut down.
If you are using a Raspberry Pi with a desktop system, try shorting the adapter interface twice to see if the case can shut down normally.
Shorting twice is equivalent to pressing the power button twice to shut down.
If it can shut down, that indicates there is an issue with the power button; if there is no response, then the adapter may be the problem.
I’ve not installed any os or even the sd card yet just built the hardware for now, is this what is causing these issues how do I check the power button?
After you install the Pironman 5 software and restart your system, you will find that all functions are ready to use. It is designed to start up automatically with the system.
Run these commands and send us the output:
cat /var/log/pironman5/pm_auto.oled.log
cat /var/log/pironman5/pm_auto.ws2812.log
