I just built a pironman 5 case yesterday and its really cool. usually when you start up you piroman the rgb lights turn on the fans start spinning and then when its booted the fans and tiny oled screen poweroff for a split second and back on. the thing is that now what happens is the fans just shut off and only the oled screen turns on. and the fans just fucking stay off. and when I go over 50 the cpu cooler doesent work so I know this is an issue. I also re connected the fan pins several times and its exactly the same outcome.
Was the pironman5 functioning properly before, and has it suddenly stopped working now?
We suggest providing a video of the issue so that we can assist you in analyzing and resolving the problem.
Have you reinstalled or updated the pironman5 software? Please provide the log information for us to confirm:
cat /var/log/pironman5/pm_auto.ws2812.log
cat /var/log/pironman5/pm_auto.fan_control.log
We recommend removing the wiring of the RGB fan from the IO expansion board and connecting it directly to the 5V and GND pins of the PI5 to see if the RGB fan operates correctly.
It may be helpful to follow the setup steps in the tutorial to reinstall the pironman5 software, and then restart the system to check if all functions of the pironman5 case work properly:
the fans randomly started working so nevermind
