I installed both 1.2.15 and 1.2.17 versions but so far no success in getting the screen to turn on nor the RGB lights on the fans. The fans do spin and I can control them from the dashboard.
I have the following ouput from early troubleshooting :
osark@raspberrypi:~ $ sudo i2cdetect -y 1
Error: Could not open file /dev/i2c-1' or /dev/i2c/1’: No such file or directory
osark@raspberrypi:~ $ cat /var/log/pironman5/main.log
25/08/22 07:53:45.210 [DEBUG] Pironman5 version: 1.2.15
25/08/22 07:53:45.211 [DEBUG] Variant: Pironman 5
25/08/22 07:53:45.211 [DEBUG] Config: {‘system’: {‘data_interval’: 1, ‘rgb_color’: ‘#0a1aff’, ‘rgb_brightness’: 50, ‘rgb_style’: ‘breathing’, ‘rgb_speed’: 50, ‘rgb_enable’: True, ‘rgb_led_count’: 4, ‘temperature_unit’: ‘C’, ‘oled_enable’: True, ‘oled_rotation’: 0, ‘oled_disk’: ‘total’, ‘oled_network_interface’: ‘all’, ‘gpio_fan_pin’: 6, ‘gpio_fan_mode’: 0}}
25/08/22 07:53:45.212 [DEBUG] Device info: {‘name’: ‘Pironman 5’, ‘id’: ‘pironman5’, ‘peripherals’: [‘storage’, ‘cpu’, ‘network’, ‘memory’, ‘history’, ‘log’, ‘ws2812’, ‘cpu_temperature’, ‘gpu_temperature’, ‘temperature_unit’, ‘oled’, ‘clear_history’, ‘delete_log_file’, ‘pwm_fan_speed’, ‘gpio_fan_state’, ‘gpio_fan_mode’], ‘version’: ‘1.2.15’, ‘app_name’: ‘pironman5’}
25/08/22 07:53:45.212 [DEBUG] PM_Auto version: 1.2.11
25/08/22 07:53:45.212 [DEBUG] PM_Dashboard version: 1.2.7
25/08/22 07:53:45.629 [INFO] PMAuto started
25/08/22 07:53:45.712 [INFO] PmDashboard started
25/08/22 07:57:17.330 [INFO] Received signal “Terminated”, cleaning up…
25/08/22 07:57:17.331 [INFO] Stopping Pironman5
25/08/22 07:57:17.331 [INFO] Stopping PMAuto
25/08/22 07:57:17.726 [INFO] Stopping PmDashboard
25/08/22 07:57:17.851 [INFO] Pironman5 stopped
25/08/22 07:57:17.852 [WARNING] Thread Thread-1 is still alive
25/08/22 07:57:18.441 [DEBUG] Pironman5 version: 1.2.15
25/08/22 07:57:18.441 [DEBUG] Variant: Pironman 5
25/08/22 07:57:18.441 [DEBUG] Config: {‘system’: {‘data_interval’: 1, ‘rgb_color’: ‘#0a1aff’, ‘rgb_brightness’: 50, ‘rgb_style’: ‘breathing’, ‘rgb_speed’: 50, ‘rgb_enable’: True, ‘rgb_led_count’: 4, ‘temperature_unit’: ‘C’, ‘oled_enable’: True, ‘oled_rotation’: 0, ‘oled_disk’: ‘total’, ‘oled_network_interface’: ‘all’, ‘gpio_fan_pin’: 6, ‘gpio_fan_mode’: 2}}
25/08/22 07:57:18.441 [DEBUG] Device info: {‘name’: ‘Pironman 5’, ‘id’: ‘pironman5’, ‘peripherals’: [‘storage’, ‘cpu’, ‘network’, ‘memory’, ‘history’, ‘log’, ‘ws2812’, ‘cpu_temperature’, ‘gpu_temperature’, ‘temperature_unit’, ‘oled’, ‘clear_history’, ‘delete_log_file’, ‘pwm_fan_speed’, ‘gpio_fan_state’, ‘gpio_fan_mode’], ‘version’: ‘1.2.15’, ‘app_name’: ‘pironman5’}
25/08/22 07:57:18.441 [DEBUG] PM_Auto version: 1.2.11
25/08/22 07:57:18.441 [DEBUG] PM_Dashboard version: 1.2.7
25/08/22 07:57:18.513 [INFO] PMAuto started
25/08/22 07:57:18.583 [INFO] PmDashboard started
25/08/22 08:13:02.876 [INFO] Received signal “Terminated”, cleaning up…
25/08/22 08:13:02.876 [INFO] Stopping Pironman5
25/08/22 08:13:02.876 [INFO] Stopping PMAuto
25/08/22 08:13:03.851 [INFO] Stopping PmDashboard
25/08/22 08:13:04.934 [INFO] Pironman5 stopped
25/08/22 08:13:04.934 [WARNING] Thread Thread-1 is still alive
25/08/22 08:13:35.311 [INFO]
25/08/22 08:13:35.320 [INFO] ############################################################
25/08/22 08:13:35.320 [DEBUG] Config path: /opt/pironman5/venv/lib/python3.11/site-packages/pironman5/config.json
25/08/22 08:13:35.320 [DEBUG] Pironman5 version: 1.2.17
25/08/22 08:13:35.320 [DEBUG] Variant: Pironman 5
25/08/22 08:13:35.320 [DEBUG] Config: {‘system’: {‘data_interval’: 1, ‘rgb_color’: ‘#0a1aff’, ‘rgb_brightness’: 50, ‘rgb_style’: ‘breathing’, ‘rgb_speed’: 50, ‘rgb_enable’: True, ‘rgb_led_count’: 4, ‘temperature_unit’: ‘C’, ‘oled_enable’: True, ‘oled_rotation’: 0, ‘oled_disk’: ‘total’, ‘oled_network_interface’: ‘all’, ‘gpio_fan_pin’: 6, ‘gpio_fan_mode’: 0, ‘debug_level’: ‘INFO’}}
25/08/22 08:13:35.321 [DEBUG] Device info: {‘name’: ‘Pironman 5’, ‘id’: ‘pironman5’, ‘peripherals’: [‘storage’, ‘cpu’, ‘network’, ‘memory’, ‘history’, ‘log’, ‘ws2812’, ‘cpu_temperature’, ‘gpu_temperature’, ‘temperature_unit’, ‘oled’, ‘clear_history’, ‘delete_log_file’, ‘pwm_fan_speed’, ‘gpio_fan_state’, ‘gpio_fan_mode’], ‘version’: ‘1.2.17’, ‘app_name’: ‘pironman5’}
25/08/22 08:13:35.321 [DEBUG] PM_Auto version: 1.2.12
25/08/22 08:13:35.321 [DEBUG] PM_Dashboard version: 1.2.10
25/08/22 08:13:43.667 [INFO] PMAuto started
25/08/22 08:13:43.754 [INFO] PmDashboard started
