I recently installed Batocera on a Raspberry Pi 5, using an SD card for the OS and an NVMe drive for storage. The Pironman5 Dashboard was working for a few minutes after I followed the instructions on setting it up here: Set up on Batocera.linux — SunFounder Pironman 5 documentation
The dashboard stopped responding pretty quickly, but the system is still online. I am not very familiar with Batocera, so I don’t know where to start troubleshooting - so any help would be appreciated.
There are currently some compatibility issues between the Batocera system and Pironman5 software. Our team is actively working with Batocera developers to address these concerns through software updates and improvements.
In the meantime, we recommend using alternative systems that are fully compatible with Pironman5 to ensure optimal performance.
Thanks - I will stick with Batocera since it is working well on the Raspberry Pi as a retro game emulator. Will you make an announcement when things are fixed?
FYI - I am on Batocera 40. Batocera 41 was very broken.
Absolutely. Once the compatibility issues between Batocera and Pironman5 are resolved, we will notify you
