Battery Failure or Something Similar on Pi-CarX
Hi, I ran my picar x for a while one time, and since then then it hasn’t been able to charge. Meaning, as I plug it in the red charging light comes on and never turns off even if i charge it for multiple days. Also, if I try to drive it, it will work for a couple minutes and then the wheels turn in opposite directions. What happened and how can I fix it. Thanks
Just a thought. If your battery has discharged beyond a certain point, it may be possible that your usb charger may not be able to supply sufficient charge current. Are you using the official rpi charger? Have you tried a different charger?
Good thought. I am using the one that came with it. I can try a higher current charger too.
Please contact service@sunfounder.com and provide your order details and address to get a battery.
