I’m curious to know if there is a Fritzing part for the BreadVolt Power Bank? I have seen a drawing with it but cannot find it as part of the parts catalog nor on the SunFounder website. I use this frequently on projects and would like to include it in the breadboard diagrams. New to Fritzing in case I’ve missed something.
Thanks in advance.
Currently, we have not yet developed an official Fritzing part for the BreadVolt Power Bank.
You can create a custom part by referring to Fritzing’s part creation guide. To assist you, we have prepared the key specifications:
Physical dimensions: 52mm × 32mm × 24mm
Pinout includes: 3.3V output, 5V output, GND, USB-C charging input, and a separate switch interface.
You can use a free tool like Inkscape to draw the SVG vector graphics (matching the Breadboard and Schematic views) and then follow the official Fritzing tutorial to define the pin properties. Once created, the part can be saved permanently in your personal library for direct use in future projects.
We hope this information helps.
Thank you for the reply! I will give that a try and thanks for the helpful information.
Cheers!
