I have a Pironman 5 MAX case with a Raspberry Pi 5 16 GB with a Pimoroni Breakout Garden attached to the external GPIO header. It looks like the vibration sensor wake up of the Pironman OLED does not work when the Breakout Garden is plugged in, and works if I remove it. I do not have anything attached to the Garden at pin 26, only few breakout modules in the SPI/I2C conectors.
pironman5 -c shows:
“vibration_switch_pin”: 26,
“vibration_switch_pull_up”: false
It also seems to block the fan LEDs (pin 5 in config) which I don’t mind
. Nothing at the Graden pin 5 either.
Vaclav
