I recently purchased a new 10.1" touchscreen from SunFounder and noticed that the display brightness is significantly lower than a previous unit.
To help illustrate the issue, I attached comparison photos:
- Panel A (left) is from a previous purchase (dated 2022.11.13) and shows much higher brightness.
- Panel B (right) is from a recently purchased unit. Both use the RM101_V3.0 board, but B appears much dimmer even at max settings.
I’ve tested:
- Gamma (1.8, 2.0, 2.2) – 1.8 is brightest, but still dim.
- Backlight and Brightness – already set to maximum.
- Ultra Vivid mode – enabled, still dim.
- 12V 5A power supply – verified and stable.
No changes in device or software between the two panels – only the panel seems different in brightness, despite using the same board version.
Questions:
- Is the reduced brightness a known issue with recent RM101_V3.0 units?
- Is there any way (firmware, hidden menu, hardware adjustment) to increase the brightness?
Appreciate any help. I’m also open to receiving support via email if needed.
Thanks!
