Continuing the discussion from Servo motor for picrawler:
Thank you for all your help on talking about the calibration process.
-I have another question.
- I have sent two photos of what my picrawler looks like after all servos were attached and set to zero by pressing the zero button
-I know they are aligned incorrectly.
-what I want to try is going about doing the alignment a little differently
-if you can please send me a picture of what a picrawler should look like that is assembled correctly after the zero button was pressed
-my thought is if I can compare my pi crawler after pressing the zero button to your picture hopefully I will be able to compare your alignment to mine and this will help me figure out which servos will have be taken off the picrawler and set it to zero and then screw it back on the picrawler - Thank you
- Dlorfel
