my picrawler (running ezblock lite os) seems to zero properly but when I begin the calibration the arms initialize to very different angles,
The calibration is barely moving any of the arms and then only infinitesimally despite my moving the various axis from -20 to 20. I am unclear why the arms are not at least misaligned consistently since they zero all the same.
I zeroed all of the servos before assembly. After assembly I made adjustments manually to correct for movement during assembly. They then aligned to the zeroed position as indicated in the assembly diagram using /picrawler/examples/servo_zeroing.py
I am trying to figure out how incorrect wiring or incorrect servo zeroing would allow it to zero correctly but then be completely misaligned for calibration. Where does picrawler store these calibration corrections for subsequent use and how do I reset that? I am wondering if somehow it is being aligned by the software to where it thinks it has been calibrated previously.
I got the same result using the /picrawler/examples/configuration/configuration.py program with full buster OS version. .
