I can’t connect to the PiCar-X any more. I used to be able to connect via Bluetooth and wifi, but no longer. I’ve rebooted the car a few times.
The PiCar is recognized on the network and I can ping it.
pi@PiCarMini:~ $ bluetoothctl -v
bluetoothctl: 5.66
1. EZBlock Studio Version Check:
Could you please confirm which version of the EZBlock Studio (PC browser version) you are currently using?
2. EZBlock OS Image Version:
May we know the version of the EZBlock OS image you downloaded and installed?
3. Local Network Verification:
Are your PC and the PiCar-X connected to the same local network?
For a successful connection, both devices must be on the same LAN.
4. Mobile App Test (Alternative Solution):
Could you try connecting the PiCar-X using the mobile version of EZBlock Studio to check if the connection works properly?
Could you please confirm which version of the EZBlock Studio (PC browser version) you are currently using?2. EZBlock OS Image Version:
May we know the version of the EZBlock OS image you downloaded and installed?3. Local Network Verification:
For a successful connection, both devices must be on the same LAN.4. Mobile App Test (Alternative Solution):
Firefox 136.0.1 (64-bit)
Note: It was connecting before. Now it stopped.
How can I determine that?
Raspios-buster-armhf-lite-2021-1-11_EzBlockOS-v1.2.3.img
Yes, they are both on the same network. You can see the successful ping from my computer to the PiCar-X
The mobile app requires Bluetooth connection. The PiCar-X isn’t recognized by Bluetooth even though the service is running.
We recommend downloading and installing EZBlock OS 2.0.2 Beta to check if the connection works properly:
Download Link
Additionally, try switching to a different network to see if that resolves the issue.
Ok, I’ll give that a try
