Hi, I’m using a PiCrawler with a Raspberry Pi Zero 2 W and the EZBlock pre-installed image.
Bluetooth works correctly: EZBlock Studio sees the crawler and connects to it. The problem is the Wi-Fi Quick Configuration. It keeps loading, then says the Wi-Fi connection failed.
I’m using iPadOS/iOS. The iPad is connected to the same Wi-Fi I’m entering in EZBlock. I’ve also tried a 2.4 GHz iPhone hotspot with a simple SSID/password, but the Wi-Fi setup still fails.
I flashed the EZBlock image using Raspberry Pi Imager 1.9.6. I previously used normal Raspberry Pi OS on the same PiCrawler and Wi-Fi/SSH worked fine, so the Pi’s Wi-Fi hardware appears to be working.
One possible issue is that my normal Wi-Fi SSID is SpectrumSetup-10. I saw other forum posts saying EZBlock may have trouble with special characters in SSIDs. Does the hyphen - cause problems?
Also, during the Wi-Fi setup, EZBlock sometimes repeatedly triggers Bluetooth pairing requests.
Is there a known Wi-Fi provisioning issue with the current EZBlock image on Raspberry Pi Zero 2 W? Is there a recommended image version, or a supported way to preconfigure Wi-Fi/SSH so the app can skip Quick Configuration?
