Cooling tower fan not getting detected
I’m facing an issue with the CPU tower cooler fan on my Pironman 5 setup.
Setup
  • Raspberry Pi 5
  • Pironman 5 case (using the provided 4-pin PWM CPU fan)
  • Raspberry Pi OS (tested on both NVMe and microSD)
Issue
  • The CPU fan spins briefly at boot
  • After the system fully boots, the fan stops and never spins again, even under load
  • CPU temperature crosses 50°C+, but the fan still does not start
What I’ve tested
  • Reinstalled Raspberry Pi OS (both SD and NVMe)
  • Tested without Pironman software installed
  • Reseated the fan connector multiple times
  • Confirmed the fan is connected to the Pi 5 4-pin fan header
Diagnostic output
ls /sys/class/thermal/
Output:
thermal_zone0
:backhand_index_pointing_right: There is no cooling_device0, which suggests the fan is not being detected by the system.
I also tried:
Result:
No such file or directory
Observation
  • Fan gets power at boot (spins briefly)
  • But appears not detected as a PWM fan by the OS
Question
  • Is this a known issue with the Pironman 5 CPU fan?
  • Could this be a cable / pinout / compatibility issue with the Pi 5 fan header?
  • Is there any additional driver or configuration required for the CPU fan (not the RGB fans)?
Any guidance would be appreciated.
The cooling tower is directly controlled by the Raspberry Pi’s fan control strategy. You can run the following commands to check whether the fan is working:
Keep the fan running at full speed
pinctrl FAN_PWM op dl
Stop the fan completely
pinctrl FAN_PWM op dh
Let the fan follow the Raspberry Pi’s default fan control strategy (typically starts at around 50°C)
pinctrl FAN_PWM a0
Please run these three commands to see if the fan responds properly. If it works as expected, you can simply leave it with pinctrl FAN_PWM a0.
By the way, may I ask — were these fan testing commands provided by an AI? Recently, I’ve noticed many people using incorrect commands when testing Raspberry Pi fans with the help of AI.
