I purchased a SunFounder 10’1 RPi kit to connect to my Solar-Assistant Orange Pi 3 LTS. The SunFounder’s HDMI signal light does not turn on. I’ve tested every startup order imaginable. In fact, the OrangePi seems to hang when connected to the SunFounder, and I have to remove the HDMI to get it to work.
However, the SunFounder screen works with my AppleTV test. I assumed it was defective, so I returned it and the new one had the same issue.
The Solar-Assistant device is here: SolarAssistant
The docs say it had full kiosk mode via HDMI: Load SolarAssistant on Raspberry Pi
When I connect the Orange Pi to a regular computer monitor via HDMI, it works fine.
I’ve tried 2 different HDMI cables, and they both work when connecting the OrangePi to the monitor, and they also work when connecting the AppleTV to the SunFounder screen.
I found some articles about reconfiguring HDMI settings on the OrangePi, but I can’t get SSH to work without reinstalling the Solar-Assistant image, which I don’t want to do.
I desperately want this to work. Any help would be appreciated.
