Having trouble accessing our Picar-X after building it
Let me start by saying I’m new to robotics and rasberry pi. Not a programmer so be gentle on me.
My son does like coding and models and remote control cars so I thought this would be a perfect gift for him.
Got him a picar-X V3 and a Raspberry Pi 4 Model B 4GB.
We built the robot (unfortunately didn’t 0 the servo’s because I didn’t understand that step at the time). We first used the paper instructions. Now it’s all built and we were able to charge the battery.
I was able to load the raspberry pi imager to a micro-sd and put it in the slot. I can see my router has connected to the raspberry pi. Now I’m trying to do the powershell step in the video with the SSH command, but it says “ssh: connect to host raspberrypi.local port 22: Connection refused”
I feel like I may be in over my head. Any tips? Are these steps necessary to use EZBlock? I nor my son are ready for python. I have EZBlock Studio on my phone, but it doesn’t see the device in bluetooth
Thanks for assistance,
Adam
1.First, configure the WiFi on your Raspberry Pi 4 (PI4). Your computer needs to connect to the same router’s WiFi so that both devices are on the same local network for a successful connection.
2.If you’re using PowerShell to connect to the PI4’s IP and the connection is refused, it’s recommended to use the PuTTY tool instead. Please refer to this tutorial for guidance: Using PuTTY.
After downloading PuTTY and connecting to the Raspberry Pi’s IP, follow our tutorial to install all the necessary library codes: Install All Modules.
Once all library codes are installed, restart the Raspberry Pi and run the servo adjustment commands in the terminal to zero the servos and secure them: Servo Adjustment.
We also have an assembly video for our product; you can follow the steps shown in the video: Assembly Video and refer to the assembly instructions here: Assembly Instructions.
If you want to control the PiCar-X using the EzBlock app, you’ll need to prepare a separate SD card and download our designated EzBlock OS image: EzBlock OS Download.
After installing EzBlock OS onto the SD card, please follow the tutorial to start it and perform the servo zeroing and assembly: Quick Guide on EzBlock.
Just a thought… Did you enable SSH in the advanced options of the imager tool?
Spf650 is correct. When using the Raspberry Pi Imager tool to install the Raspberry Pi OS, please enable SSH in the “Service” tab.
This way, once the system is successfully installed, you can enter the IP address of picar-x to establish a remote connection.
Please refer to the tutorial steps for installing the system: 2. Installing the OS — SunFounder PiCar-X Kit documentation
You all are amazing, thanks so much for your thoughtful assistance.
I was able to get it all installed and running and I’m pretty proud. My son is now using ex-block to control it and learning how it works!
Hey one small thing, on the camera module where the FFC cable tape goes in, I put the cable in backwards originally and when trying to undo it I broke one the clasps on the side so now the FFC cable tape doesn’t consistently stay in place. Is there a way to purchase a replacement camera module? I guess I would need the replacement rivets too? Let me know. Thanks so much for all your help!
Yayy! Excellent news! Have fun!!
“The clip on the camera for adavis521 has come off, and the camera module needs to be replaced.”
We can send you a replacement.
Is the rivet you require R2048?
