Hi all - I have got the home intrusion project (iot_9_intrusion_alert_system.ino code) to work fine; it sends an alert to the Blynk console and to the Blynk App when the PIR detects movement. What I can’t get it to do is send me an email notification. I’ve followed the documentation as best I could, saving each time I make a change, but there are still no “Notificatons” listed against the device when I go into the Blynk console. When I go into the “Device” and click on “Edit” and then select the Device, and select the second tab called “Notifications”, it has a switch there for “Enable notifications” and a field below for an email address, but when I put the cursor over the switch or the email field a greyed out
“no entry” symbol appears, so I can’t make any changes. So I’m wondering if I don’t have the correct permissions set somewhere. Or is adding an email event notification more complex than that; do I have to insert additional lines of code in my sketch?
Any help very gratefully received!
Thanks,
Steve
Which of our products are you currently using?
We suggest you provide us with more useful information. For example, screenshots of operations, etc.
