I purchased the Da Vinci Kit and have been trying to use the LCD1602 following the guide on page 1.1.7 I2C LCD1602. I wrote and ran the code below, but I get an error that this directory does not exist and cannot proceed.
cd ~/raphael-kit/python/
- What version of the system are you currently using.
- Did you report any errors when installing the source code? If so, please provide screenshots to us, so that we can analyze and solve the problem.
- Which path did you install the source code under, please send us the working path.
- If I am correct, you can check version of the system from the screenshot below.(If I wrong, please tell me what code I should use.)
- I don
t know what "the source code" you mentioned, but probably I dint got any errors when installing ”the source code”. - I have not changed the path to install the code, so I think “the source code” install path is the same as the path in the screenshot below.
Sorry, I understand what you mean by “that source code”. But the error I get when I use “that source code” is the very first one I wrote: “this directory does not exist”.
We recommend that you reinstall your Raspberry Pi system and go back to installing our source code: Download the Code — SunFounder Ulimate Raphael Kit for Raspberry Pi documentation Please follow the link to our tutorial to install the source code: cd ~/git clone GitHub - sunfounder/raphael-kit Reboot your Raspberry Pi after successful installation. Go run the example again: cd ~/raphael-kit/python/sudo python3 1.1.7_Lcd1602.py
Thanks to your advice, I was able to use LCD1602 correctly!
