la foto street view è vecchia. Abbiamo ristrutturato l'immobile. dobbiamo sostituirla
Saya mengalami kesulitan masuk ke Ras Pi 4. Saya mencoba melakukan flashing dengan Balena dan (setelah membaca dokumentasi Sunfounder) Ras Pi Imager. Setelah beberapa jam berdiskusi dengan Chat GPT, Claude menyarankan solusi yang berhasil: Gunakan Ras Pi Imager 1.7.5. Tidak hanya itu, versi 1.7.5 memungkinkan saya untuk menyesuaikan nama host dan mengatur Wi-Fi. Saya harus mencari di repositori GitHub Sunfounder untuk menemukan Ras Pi Imager 1.7.5. Sunfounder bisa lebih memperjelas hal ini, karena sebagian besar orang yang menggunakan EZ Block melakukannya karena suatu alasan. Bagaimanapun, langkah 1 sudah selesai dan sekarang saya telah menemukan forum ini. Selanjutnya, saya akan merakit kit ini bersama cucu-cucu saya.
Thank you very much for taking the time to share your experience, and we sincerely apologize for all the trouble the initial login step caused you.
First, we are glad to hear that you successfully logged into your Raspberry Pi 4 — the first step is complete. Your approach of using Raspberry Pi Imager 1.7.5 to flash the image and configure the hostname and Wi‑Fi is completely correct. Thank you for sharing this experience, as it will be helpful to other users facing the same issue.
Regarding the problem you encountered, here is a clear explanation: Raspberry Pi Imager version 2.0 and above has a bug — when flashing a custom image, it cannot perform Wi‑Fi network pre‑configuration, which prevents the device from connecting to the network or logging in after flashing. Therefore, we recommend downloading and installing a version below 2.0 to flash the system. The download link for version 1.9.6 is below:
:backhand_index_pointing_right: Release v1.9.6 · raspberrypi/rpi-imager · GitHub
The reason your previous use of 1.7.5 worked is precisely because it is a version below 2.0.
Regarding the documentation issue you mentioned, we completely understand your feelings — users of EZ Block often want to get started quickly, and if key information (such as the recommended Raspberry Pi Imager version) is not prominent enough, it can indeed waste a lot of time. We will forward your feedback to our documentation team and update the documentation to make this note clearer.
