Please find attached screen printout and logs as I have tried to install the software again. this time on a new SD card. it appears it is loading the pironman5 not the pironman5_max software
sorry could not upload pdf. Comments in bold
thanks for the quick response
regards
idp@Pi5:~ $ cd ~
cd ~/pironman5
Cloning into ‘pironman5’…
remote: Enumerating objects: 31, done.
remote: Counting objects: 100% (31/31), done.
remote: Compressing objects: 100% (28/28), done.
remote: Total 31 (delta 2), reused 14 (delta 0), pack-reused 0 (from 0)
Receiving objects: 100% (31/31), 30.30 KiB | 3.03 MiB/s, done.
Resolving deltas: 100% (2/2), done.
Installing for Pironman 5
Version: 1.2.25
Install build dependencies…
Run commands before install…
Install APT dependencies…
- Install APT dependencies: libopenjp2-7 python3-dev i2c-tools libfreetype6-dev libjpeg-dev kmod python3-gpiozero lsof influxdb… Done
Create working directory…
Create work directory… Done
Change work directory mode… Done
Change work directory owner… Done
Create log directory… Done
Change log directory mode… Done
Change log directory owner… Done
Create virtual environment… Done
Install PIP dependencies…
Install Python source packages…
Uninstall pironman5 old package… Done
Install pironman5 from source… Done
Uninstall pm_auto old package… Done
Install pm_auto from source… Done
Uninstall pm_dashboard old package… Done
Install pm_dashboard from source… Done
Uninstall sf_rpi_status old package… Done
Install sf_rpi_status from source… Done
Setup auto start…
Probe modules…
- add module: i2c-dev… Done
Copy device tree overlay…
- Copy dtoverlay sunfounder-pironman5.dtbo… Done
- Change work directory owner… Done
Finished
Cleanup
Whether to restart for the changes to take effect(Y/N):Y
System Restart
idp@Pi5:~ $ sudo systemctl restart pironman5.service
idp@Pi5:~ $
No LEDs (on board or fans) or OLED Display
Run Log as requested it appears to be loading pironman5 software not pironman 5 max
idp@Pi5:~ $ cat /var/log/pironman5/main.log
26/01/12 13:04:05.225 [INFO]
26/01/12 13:04:05.225 [INFO] ############################################################
26/01/12 13:04:05.225 [DEBUG] Config path: /opt/pironman5/venv/lib/python3.13/site-packages/pironman5/config.json
26/01/12 13:04:05.225 [DEBUG] Pironman5 version: 1.2.25
26/01/12 13:04:05.225 [DEBUG] Variant: Pironman 5
26/01/12 13:04:05.225 [DEBUG] Config: {‘system’: {‘data_interval’: 1, ‘rgb_color’: ‘#0a1aff’, ‘rgb_brightness’: 50, ‘rgb_style’: ‘breathing’, ‘rgb_speed’: 50, ‘rgb_enable’: True, ‘rgb_led_count’: 4, ‘temperature_unit’: ‘C’, ‘oled_enable’: True, ‘oled_rotation’: 0, ‘oled_disk’: ‘total’, ‘oled_network_interface’: ‘all’, ‘gpio_fan_pin’: 6, ‘gpio_fan_mode’: 0, ‘debug_level’: ‘INFO’}}
26/01/12 13:04:05.225 [DEBUG] Device info: {‘name’: ‘Pironman 5’, ‘id’: ‘pironman5’, ‘peripherals’: [‘storage’, ‘cpu’, ‘network’, ‘memory’, ‘history’, ‘log’, ‘ws2812’, ‘cpu_temperature’, ‘gpu_temperature’, ‘temperature_unit’, ‘oled’, ‘clear_history’, ‘delete_log_file’, ‘pwm_fan_speed’, ‘gpio_fan_state’, ‘gpio_fan_mode’], ‘version’: ‘1.2.25’, ‘app_name’: ‘pironman5’}
26/01/12 13:04:05.225 [DEBUG] PM_Auto version: 1.2.12
26/01/12 13:04:05.226 [DEBUG] PM_Dashboard version: 1.2.10
26/01/12 13:04:06.454 [INFO] PMAuto started
26/01/12 13:04:06.567 [INFO] PmDashboard started
26/01/12 13:06:29.883 [INFO] Received signal “Terminated”, cleaning up…
26/01/12 13:06:29.883 [INFO] Stopping Pironman5
26/01/12 13:06:29.884 [INFO] Stopping PMAuto
26/01/12 13:06:30.503 [INFO] Stopping PmDashboard
26/01/12 13:06:30.780 [INFO] Pironman5 stopped
26/01/12 13:06:30.781 [WARNING] Thread Thread-1 is still alive
26/01/12 13:06:31.370 [INFO]
26/01/12 13:06:31.371 [INFO] ############################################################
26/01/12 13:06:31.371 [DEBUG] Config path: /opt/pironman5/venv/lib/python3.13/site-packages/pironman5/config.json
26/01/12 13:06:31.371 [DEBUG] Pironman5 version: 1.2.25
26/01/12 13:06:31.371 [DEBUG] Variant: Pironman 5
26/01/12 13:06:31.371 [DEBUG] Config: {‘system’: {‘data_interval’: 1, ‘rgb_color’: ‘#0a1aff’, ‘rgb_brightness’: 50, ‘rgb_style’: ‘breathing’, ‘rgb_speed’: 50, ‘rgb_enable’: True, ‘rgb_led_count’: 4, ‘temperature_unit’: ‘C’, ‘oled_enable’: True, ‘oled_rotation’: 0, ‘oled_disk’: ‘total’, ‘oled_network_interface’: ‘all’, ‘gpio_fan_pin’: 6, ‘gpio_fan_mode’: 0, ‘debug_level’: ‘INFO’}}
26/01/12 13:06:31.371 [DEBUG] Device info: {‘name’: ‘Pironman 5’, ‘id’: ‘pironman5’, ‘peripherals’: [‘storage’, ‘cpu’, ‘network’, ‘memory’, ‘history’, ‘log’, ‘ws2812’, ‘cpu_temperature’, ‘gpu_temperature’, ‘temperature_unit’, ‘oled’, ‘clear_history’, ‘delete_log_file’, ‘pwm_fan_speed’, ‘gpio_fan_state’, ‘gpio_fan_mode’], ‘version’: ‘1.2.25’, ‘app_name’: ‘pironman5’}
26/01/12 13:06:31.371 [DEBUG] PM_Auto version: 1.2.12
26/01/12 13:06:31.371 [DEBUG] PM_Dashboard version: 1.2.10
26/01/12 13:06:32.496 [INFO] PMAuto started
26/01/12 13:06:32.566 [INFO] PmDashboard started
idp@Pi5:~ $
Note after going into raspi-config enabling SPI and I2C and rebooting the board LEDs ( not fan LEDs) and OLED screen came to life. Still no menu items to control fan LED or OLED time
Logs below
idp@Pi5:~ $ cat /var/log/pironman5/pm_auto.oled.log
26/01/12 13:04:05.545 [ERROR] Failed to initialize OLED
26/01/12 13:06:31.390 [ERROR] Failed to initialize OLED
26/01/12 13:09:43.061 [ERROR] ‘SSD1306’ object has no attribute ‘draw’
File “/opt/pironman5/venv/lib/python3.13/site-packages/pm_auto/utils.py”, line 11, in wrapper
return func(self, \*args, \*\*kwargs)
File “/opt/pironman5/venv/lib/python3.13/site-packages/pm_auto/oled.py”, line 222, in sleep
self.oled.clear()
File “/opt/pironman5/venv/lib/python3.13/site-packages/pm_auto/ssd1306.py”, line 293, in clear
self.draw.rectangle((0, 0, self.width, self.height), outline=0, fill=0)
AttributeError: ‘SSD1306’ object has no attribute ‘draw’
26/01/12 13:17:36.509 [DEBUG] Update temperature_unit to C
26/01/12 13:17:36.512 [DEBUG] Update oled_rotation to 0
26/01/12 13:17:36.512 [DEBUG] Update oled_disk to total
26/01/12 13:17:36.512 [DEBUG] Update oled_network_interface to all
26/01/12 13:17:36.512 [DEBUG] Update oled_enable to True
26/01/12 13:17:36.512 [DEBUG] OLED wake up
26/01/12 13:17:41.401 [INFO] Connected to eth0: 192.168.68.68
26/01/12 13:17:41.402 [INFO] Connected to wlan0: 192.168.68.78
idp@Pi5:~ $ ^C
26/01/12 13:16:46.966 [INFO] Received signal “Terminated”, cleaning up…
26/01/12 13:16:46.966 [INFO] Stopping Pironman5
26/01/12 13:16:46.966 [INFO] Stopping PMAuto
26/01/12 13:16:47.718 [INFO] Stopping PmDashboard
26/01/12 13:16:48.674 [INFO] Pironman5 stopped
26/01/12 13:16:48.674 [WARNING] Thread Thread-1 is still alive
26/01/12 13:17:36.131 [INFO]
26/01/12 13:17:36.133 [INFO] ############################################################
26/01/12 13:17:36.133 [DEBUG] Config path: /opt/pironman5/venv/lib/python3.13/site-packages/pironman5/config.json
26/01/12 13:17:36.133 [DEBUG] Pironman5 version: 1.2.25
26/01/12 13:17:36.133 [DEBUG] Variant: Pironman 5
26/01/12 13:17:36.133 [DEBUG] Config: {‘system’: {‘data_interval’: 1, ‘rgb_color’: ‘#0a1aff’, ‘rgb_brightness’: 100, ‘rgb_style’: ‘breathing’, ‘rgb_speed’: 50, ‘rgb_enable’: True, ‘rgb_led_count’: 4, ‘temperature_unit’: ‘C’, ‘oled_enable’: True, ‘oled_rotation’: 0, ‘oled_disk’: ‘total’, ‘oled_network_interface’: ‘all’, ‘gpio_fan_pin’: 6, ‘gpio_fan_mode’: 3, ‘debug_level’: ‘INFO’}}
26/01/12 13:17:36.134 [DEBUG] Device info: {‘name’: ‘Pironman 5’, ‘id’: ‘pironman5’, ‘peripherals’: [‘storage’, ‘cpu’, ‘network’, ‘memory’, ‘history’, ‘log’, ‘ws2812’, ‘cpu_temperature’, ‘gpu_temperature’, ‘temperature_unit’, ‘oled’, ‘clear_history’, ‘delete_log_file’, ‘pwm_fan_speed’, ‘gpio_fan_state’, ‘gpio_fan_mode’], ‘version’: ‘1.2.25’, ‘app_name’: ‘pironman5’}
26/01/12 13:17:36.134 [DEBUG] PM_Auto version: 1.2.12
26/01/12 13:17:36.134 [DEBUG] PM_Dashboard version: 1.2.10
26/01/12 13:17:41.343 [INFO] PMAuto started
26/01/12 13:17:41.422 [INFO] PmDashboard started
idp@Pi5:
