OLED error in Pico W lesson 25
Following along with lesson 25,
writing the same code as in the
lesson to display “Hello World!”, I get
an error message instead of it
running. The library for ssd1306 is
loaded. Here is the error message:
MPY: soft reboot
File “”, line 5, in
File “/lib/[ssd1306.py](javascript:void(0);)”, line 119, in _init_
File “/lib/[ssd1306.py](javascript:void(0);)”, line 38, in _init_
File “/lib/[ssd1306.py](javascript:void(0);)”, line 75, in init_display
File “/lib/[ssd1306.py](javascript:void(0);)”, line 124, in write_cmd
OSError: [Errno 5] EIO
I did notice that the name of the
library I loaded looks different from
what was in the lesson but is still
for ssd1306. The program stops at
line 5.
Which product’s project example are you currently running?
Based on the error information you provided, the core issue is a communication failure between the Pico W and the OLED screen (SSD1306 driver), rather than the library file being completely unusable (the library loaded successfully, but the error occurred in the write_cmd function related to communication).
The possible causes are:
Hardware connection error (incorrect I2C pin wiring, poor contact).
I2C communication parameter mismatch (the I2C port/address in the tutorial does not match the actual hardware).
Library version compatibility issue (different versions of the SSD1306 library may require different initialization parameters).
Unstable power supply (insufficient power to the OLED screen, leading to communication failure).
It turns out that the problem was that the IO pins specified did not work. I moved them to another set of pins and everything worked properly.
Ken
