OLED Screen for Android 16: Tutorial
I got the Pironman 5 OLED working on Android 16 using Termux with a Python system monitor (CPU, RAM, Disk bars).
Install Termux from the play store or aptoid
!Some commands may or may not need to be ran as sudo!
SETUP:
pkg update -y
pkg upgrade -y
pkg install -y python
pkg install -y clang
pkg install -y libjpeg-turbo
pkg install -y libpng
pkg install -y zlib
pip install pillow
pip install luma.oled
pip install psutil
CREATE SCRIPT:
sudo nano /data/data/com.termux/files/home/oled_test.py
PASTE THIS: use all of it to where it ends at the line of asterisks*
import psutil
from luma.oled.device import ssd1306
from luma.core.interface.serial import i2c
from PIL import Image, ImageDraw, ImageFont
# OLED setup
serial = i2c(port=1, address=0x3C)
device = ssd1306(serial)
# Display layout
WIDTH = 128
HEIGHT = 64
BAR_X = 72
BAR_WIDTH = 50
BAR_HEIGHT = 8
font = ImageFont.load_default()
last_values = None
# Prime CPU reading
psutil.cpu_percent(interval=None)
# Get CPU temperature
def get_cpu_temp():
    with open("/sys/devices/virtual/thermal/thermal_zone0/temp", "r") as f:
        temp = int(f.read()) / 1000.0
        return temp
except:
    return 0.0
# Draw bar function
def draw_bar(draw, label, value, y, display_value=None, unit=“%”):
percent = max(0, min(int(value), 100))
filled = int((percent / 100) \* BAR_WIDTH)
filled = max(filled, 1)
\# Text display
if display_value is None:
    text = f"{label} {percent}{unit}"
else:
    text = f"{label} {display_value}{unit}"
draw.text((0, y), text, font=font, fill=255)
\# Bar outline
draw.rectangle((BAR_X, y, BAR_X + BAR_WIDTH, y + BAR_HEIGHT), outline=255, fill=0)
\# Bar fill
right_edge = max(BAR_X + filled - 1, BAR_X + 1)
draw.rectangle((BAR_X + 1, y + 1, right_edge, y + BAR_HEIGHT - 1), fill=255)
# Main loop
cpu = int(psutil.cpu_percent(interval=None))
ram = int(psutil.virtual_memory().percent)
disk = int(psutil.disk_usage('/storage/emulated/0').percent)
\# Temperature
temp_c = get_cpu_temp()
THROTTLE_TEMP = 80
temp_percent = int(max(0, min((temp_c / THROTTLE_TEMP) \* 100, 100)))
values = (cpu, ram, disk, temp_percent)
if values != last_values:
    image = Image.new("1", (WIDTH, HEIGHT), 0)
    draw = ImageDraw.Draw(image)
    draw_bar(draw, "CPU", cpu, 2)
    draw_bar(draw, "RAM", ram, 18)
    draw_bar(draw, "DSK", disk, 34)
    draw_bar(draw, "TMP", temp_percent, 50, int(temp_c), "C")
    device.display(image)
    last_values = values
time.sleep(2)
RUN:
sudo python /data/data/com.termux/files/home/oled_test.py
AUTO START ON BOOT:
pkg install -y termux-api
mkdir -p ~/.termux/boot
sudo nano ~/.termux/boot/oled.sh
PASTE:
#!/data/data/com.termux/files/usr/bin/bash
sleep 10
MAKE EXECUTABLE:
chmod +x ~/.termux/boot/oled.sh
NOTES:
  • Disk is using /storage/emulated/0
  • Temp is placeholder (0 for now)
  • sleep 10 helps prevent startup conflicts
  • I have found that if the OLED is flashing or acting weird after editing it the script for it, usually restarting android itself helps
  • Some commands may or may not need to be ran as sudo
  • My next project is to get the LED’s working
This is a generated pic of what it will look like, the temperature bar is from 0-80c and 100% represents thermal throttling.
I also just created a post today to get the RGB lights functioning with android 16 also. It was not easy and quite a headache but here you go. I now have both the OLED and RGB functioning through android. If you choose to use these tutorials good luck. I hope I outlined everything correctly.
We appreciate you taking the time to contribute this guide. Please keep us updated on your progress with getting the LEDs working – many users would likely be interested in that as well.
