Pironman5 RGB on KonstaKANG Android 16 (Working Setup Guide)
This guide documents the exact steps that successfully got the SunFounder Pironman5 RGB LEDs working under KonstaKANG Android 16 on a Raspberry Pi 5.
Hardware / Software Used
Raspberry Pi 5
SunFounder Pironman5 case
Root access via Magisk
Termux
SPI enabled
What Was Learned
The Pironman5 RGB LEDs:
Use WS2812 LEDs
Use SPI communication
Use
/dev/spidev0.0 -
Use Adafruit NeoPixel SPI library
Require the
sunfounder-pironman5.dtbooverlay
The official Pironman5 software uses:
adafruit-circuitpython-neopixel-spi -
NeoPixel_SPI -
GRB color order
4 LEDs
Step 1 — Install Required Packages in Termux
Open Termux and install:
pkg update
pkg install python clang
pip install spidev
pip install adafruit-blinka
pip install adafruit-circuitpython-neopixel-spi
pip install "setuptools<70" --force-reinstall
The setuptools downgrade is important because newer setuptools versions remove pkg_resources, which Adafruit libraries expect.
Verify:
python -c "import pkg_resources; print('pkg_resources works')"
Step 2 — Verify SPI Devices Exist
Run:
su
ls -l /dev/spidev*
Working output included:
/dev/spidev0.0
/dev/spidev0.1
/dev/spidev10.0
The working RGB configuration ultimately used:
/dev/spidev0.0
Step 3 — Enable Pironman Overlay
Verify overlay exists:
ls /boot/overlays | grep sunfounder
Expected:
Edit:
nano /boot/config.txt
Add:
dtoverlay=sunfounder-pironman5
dtparam=spi=on
Reboot:
reboot
Step 4 — Create Working RGB Script
Create:
nano /data/data/com.termux/files/home/pironman_rgb.py
Paste:
import spidev
import neopixel_spi as neopixel
class AndroidSPI:
def __init__(self):
self.spi = spidev.SpiDev()
self.spi.open(0,0)
self.spi.max_speed_hz = 6400000
self.spi.mode = 0
self.locked = False
def try_lock(self):
self.locked = True
return True
def unlock(self):
self.locked = False
def configure(self, baudrate=6400000, phase=0, polarity=0, bits=8):
self.spi.max_speed_hz = baudrate
self.spi.mode = (polarity << 1) | phase
def write(self, buf, start=0, end=None):
if end is None:
end = len(buf)
self.spi.writebytes(list(buf[start:end]))
pixels = neopixel.NeoPixel_SPI(
AndroidSPI(),
4,
pixel_order=neopixel.GRB,
auto_write=False,
brightness=0.15
pixels.fill((0,255,0))
pixels.show()
print("RGB active")
time.sleep(60)
Step 5 — Run RGB Script
Run as a one-line command:
su -c "chmod 666 /dev/spidev0.0 && cd /data/data/com.termux/files/home && /data/data/com.termux/files/usr/bin/python pironman_rgb.py"
If successful, LEDs should turn on.
Step 6 — Change RGB Color
Edit this line:
Examples:
Green:
(0,255,0)
Red:
(255,0,0)
Blue:
(0,0,255)
Purple:
(255,0,255)
White:
(255,255,255)
Dark Green:
(0,80,0)
Step 7 — Adjust Brightness
Brightness is controlled here:
brightness=0.15
Examples:
Very dim:
brightness=0.05
Dim:
brightness=0.1
Medium:
brightness=0.3
Bright:
brightness=0.6
Maximum:
brightness=1.0
Step 8 — Create RGB OFF Script
Create:
nano /data/data/com.termux/files/home/rgb_off.py
Paste:
import spidev
class AndroidSPI:
def __init__(self):
self.spi.open(0,0)
self.spi.mode = 0
self.locked = False
def try_lock(self):
self.locked = True
return True
def unlock(self):
self.locked = False
if end is None:
end = len(buf)
AndroidSPI(),
4,
auto_write=False
pixels.fill((0,0,0))
pixels.show()
print("RGB OFF")
Step 9 — Turn RGB OFF
Kill RGB process:
su -c "pkill -f pironman_rgb.py"
Then:
su -c "chmod 666 /dev/spidev0.0 && cd /data/data/com.termux/files/home && /data/data/com.termux/files/usr/bin/python rgb_off.py"
Optional — Run RGB Automatically At Boot
Create boot script:
su
mkdir -p /data/adb/service.d
Create:
/data/adb/service.d/pironman_rgb.sh
Contents:
#!/system/bin/sh
sleep 30
/data/data/com.termux/files/usr/bin/python /data/data/com.termux/files/home/pironman_rgb.py &
Make executable:
chmod 755 /data/adb/service.d/pironman_rgb.sh
Reboot.
Notes
LEDs may remain on after shutdown because WS2812 LEDs remember their last state.
Sudden crashes/power loss may leave LEDs frozen on.
Android board detection for Adafruit Blinka does not work normally on KonstaKANG Android, so a custom SPI wrapper class was required.
/dev/spidev10.0did not work for RGB control. -
The working SPI bus was:
/dev/spidev0.0
Final Result
Pironman5 RGB LEDs successfully working on KonstaKANG Android 16 using:
Python
Termux
Root access
SPI
NeoPixel SPI
SunFounder overlay
