I have followed the configuration steps and am having trouble getting the OLED to turn on. The lights and fan are working correctly. Here’s the log. You can see the OLED error towards the bottom. Any ideas? (FYI I have tried this many times: Pironman support for hassio/Home Assistant - #5 by SunFounder_Moderator)
Add-on: Pironman
Pironman support
Add-on version: 1.0.3
System: Home Assistant OS 10.3 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.7.2
Home Assistant Supervisor: 2023.07.1
[12:48:04] INFO: Configuring timezone (America/Chicago)…
temperature_unit: F
fan_temp: 50
display_always_on: true
display_on_for: 30
rgb_on: true
rgb_style: colorful
rgb_color: 0a1aff
rgb_speed: 50
rgb_freq: 1000
rgb_pin: 10
set temperature unit to F
set the fan on temperature to 50
set screen_always_on to on
set screen_off_time to 30
set rgb_enable to on
set rgb_switch to on
set rgb_style to colorful
set rgb_color to 0a1aff
set rgb_blink_speed to 50
set rgb_pwm_freq to 1000
set rgb io to pin 10 (spi)
run in foreground
23/07/20 12:48:07,770 [DEBUG] Home Assistant Addon mode
------------------------23/07/20 12:48:07------------------------
pironman version: 2.3.0
username:
Kernel Version:
Linux 6fa7f6d2-pironman 6.1.21-v8 #1 SMP PREEMPT Thu Jun 15 17:49:15 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
PCB info:
Revision : c03115
23/07/20 12:48:07,821 [DEBUG] power_key_pin : 16
23/07/20 12:48:07,822 [DEBUG] fan_pin : 6
23/07/20 12:48:07,822 [DEBUG] update_frequency : 0.5
23/07/20 12:48:07,823 [DEBUG] temp_unit : F
23/07/20 12:48:07,824 [DEBUG] fan_temp : 50.0
23/07/20 12:48:07,825 [DEBUG] screen_always_on : True
23/07/20 12:48:07,825 [DEBUG] screen_off_time : 30
23/07/20 12:48:07,826 [DEBUG] rgb_enable : True
23/07/20 12:48:07,826 [DEBUG] rgb_switch: True
23/07/20 12:48:07,827 [DEBUG] rgb_style : colorful
23/07/20 12:48:07,827 [DEBUG] rgb_color : 0a1aff
23/07/20 12:48:07,828 [DEBUG] rgb_blink_speed : 50
23/07/20 12:48:07,828 [DEBUG] rgb_pwm_freq : 1000
23/07/20 12:48:07,829 [DEBUG] rgb_pin : 10
23/07/20 12:48:07,859 [DEBUG] oled init failed:
[Errno 2] No such file or directory
23/07/20 12:48:07,872 [DEBUG] rgb_show
23/07/20 12:48:07,878 [DEBUG] rgb_show: colorful
