I was wondering if is normal that the status light(one that the light pipe goes to) should be always off after i start using my NVME SSD. if i use my sd card is always on.
thank you
thank you
Could you please confirm if the system boots and operates normally from the SSD despite the indicator light turning off?
Here’s some additional information to help clarify:
dmesg output).If you encounter any issues during the process, we kindly suggest recording a video of the problem and sharing it with us.
Ok thank you.
I did the dmesg cmd and only weird thing i saw was
[0.3989901] nvme nvme0: failed to allocate host memory buffer.
[2.386244] rpivid_hevc: module is from the staging directory, quality is unknown, you have been warned.
And 5 instances of faking a node
And shutdown seems to take a bit long between 20 to 45 sec
Are you currently able to boot the system from the SSD properly?
Regarding system shutdown:
Shutdown requires time, and there is no fixed standard for the duration.
For the Raspberry Pi 5, all running software must be properly closed before the system can shut down. Therefore, the shutdown process takes some time.
Thank you so much for clarifying it.
Also i saw there is a new version of the software. Doing the apt update and upgrade will update it or there is another procedure?
Thank you again for your time
Yes, these commands will update your system:
sudo apt update
sudo apt upgrade
