Hi all;
What am i missing? There are no leds on when I plug in the NVMe board, even with out a NVMe stick. The four pins appear to pass through properly from the power board underneath. Wiggling makes no difference.
Otherwise it works great!
D
Hi all;
D
Do you have the ribbon cable oriented properly?
Pretty sure I do. The black ends are facing correctly. The power led would likely light regardless, I’d think. (I have been wrong before!)
1.Appreiciate you can provide a video so we can know the issue well.
2.Please check that the FPC cable connecting your PI5 to the NVMe PIP is properly connected. You can refer to the steps shown in the video to confirm the connection.
3.You could try replacing the FPC cable with a spare one and see if that resolves the issue.
Thabk you for the suggestion!
I didn’t have sucess with the other cable either, unfortunately!
Power (correct voltage) is getting to the board , measured 5v (correct polarity) at the base of the pin connector (solder points) on the pip board.
If no NVMe is not present or cable is not present, it still doesn’t looked powered up.
Power LED has no voltage.
You need to insert an SSD. The Pironman NVMe PIP is an adapter for the SSD.
Since I haven’t seen you mention whether you have connected an SSD or not, please let us know what specification of SSD you are using.
Regarding the compatibility of Pironman5 with certain SSDs, our tutorial link has the relevant reference information. Please check the tutorial:Compitable NVMe SSD — SunFounder Pironman documentation
I’m using this one:
Crucial P3 Plus 2TB PCIe Gen4 3D NAND NVMe M.2 SSD, up to 5000MB/s - CT2000P3PSSD8
The compatible list lists “Crucial P3 Plus M.2”.
So I thought it was OK. Is that not the case? Or is that hard to tell?
Do you enable PCIe into \boot\firmware\config.txt, as shown in tutorial? Booting from NVMe SSD — SunFounder Pironman documentation
1.Weirdyguy is correct.
Please follow the steps in our online tutorial:
https://docs.sunfounder.com/projects/pironman5/en/latest/advanced/booting_from_ssd.html
If booting from an SSD, the PCIe connector is not enabled by default. (As shown in the image)
2.Configure booting from the SSD:
sudo rpi-eeprom-config --edit
Change the BOOT_ORDER line to the following:
BOOT_ORDER=0xf416
3.After configuring the settings, restart and boot up pironman5. During the boot process, observe the status of the Pi5 NVMe PIP indicator lights.
STA: Status LED indicator.
PWR: Power LED indicator.
In the working state, the PWR LED will be a solid green light, and the STA LED will be flashing orange.
No dice! Those entries are already there. I toggled the dtparam=pciex1_gen=3 as well.
No lights; no device.
Please contact service@sunfounder.com. We will arrange tosend you a NVMe PIP board.
I spent most of yesterday going around and around. Different SSD’s, reseating the cable. The only thing that gave me hope and kept me from trying to get a warranty exchange was, when the system first powers up and is at the boot loader, the Power indicator light is on for a bit on NVMe PIP but would then turn off and I would get the “pcie: link down” before the OS started booting. I made all the changes found in the docs and the forum to the config.txt and eeprom. I tried my Samsung 512GB PM991a (MZ-9LQ515B, Steamdeck SSD, upgraded to 2TB), a Western Digital PC SN520, and even opened a new Sabrent Rocket NVMe 4.0 (RMA took for ever and still had it sitting on my desk) since it was on the “good list”. At the end of night I ended up spending $35.00 on Amazon for the Team MP33 512GB (overnight delivery was available). I also swapped out PCIE cable with the spare that came with the PIronman5 kit. Amazingly I finally saw the STA (status?) light illuminate for the first time. Cloned Ubuntu over to the SSD from an eternal connected SD after booting into PI-OS, rebooted and it booted up flawlessly off the NVMe.
I’m glad to hear that you were able to resolve the issue.
So, the current problem you’re facing is that the FPC cable is not connected properly, or is it one of the FPC cables that is not functioning?
If it’s one of the FPC cables that is not working, we can arrange to send you a replacement FPC cable.
Can you please confirm whether I should expect to see a power LED even if there is no compatible SSD present? Or will the power LED only appear if there is a compatible SSD?
Currently I see no LEDs of any kind lit on the board. It would be useful to know whether this means there is a problem irrespective of a compatible SSD being present. Your answer here does not clarify this either way.
Even if the nvme PIP module is not connected to an SSD, if the FPC cable is correctly connected, the nvme PIP module will light up the power indicator light after the chassis is powered on. (PWR)
It is recommended that you verify according to our FAQ solution:
And tell us the verification results one by one.
