can the raspberry pi camera2 be used to upgrade the camera on the picar-x?
The Raspberry Pi V2 camera is compatible with picar-x.
The dimensions of the V1 and V2 cameras are the same, and both use the 15-pin MIPI CSI-2 interface.
Is all the software compatible or will i need to make changes?
thank you for the help.
Yes. No changes are required. You can just follow the picar-x product tutorial as normal.
