I was wondering if there is information somewhere on the API of the picar-x lib (apart from examining the examples).
I’m especially interested in steering. It seems my picar has a shorter turning circle when turning left than when turning right. I have calibrated and the offset I have is -4.4
I’m assuming there is a maximum limit somewhere. and that it is the same for left and right.
And what I am really after is knowledge on what steering angle and speed and duration will lead to a 90 degree turn. Basically I am trying to let the picar-x drive touching the four corner points of a rectangle.
Thank you very much for contacting us and reporting the steering issue with your PiCar-X. We are sorry for the trouble this has caused you. We have received the forum link you provided, but unfortunately we are currently unable to open the post, so we cannot see the specific details of the problem yet.
To help us locate the issue as quickly as possible, could you please provide the following information:
Please describe the exact symptom: for example, do the wheels stay turned to one side, does the steering servo not rotate at all, or does the problem occur when running the steering example program?
Have you completed the servo zeroing procedure before assembly? The correct steps are:
Power on the Robot HAT;
Briefly press the zero button;
Connect the servo cable to the PWM pin; the servo should return to its zero position;
Do not unplug the zeroed servo yet; fix it in place according to the assembly steps, and then unplug it;
Repeat the same steps for the other servos: zero them first, then assemble and fix them.
Please record a video that clearly shows the problem (for example, the wheel movement while running the steering example program), upload it to Google Drive or another cloud drive, and share the link with us. Please set the link permission to ‘Anyone with the link can view’, otherwise we will not be able to open it.
Once we receive this information, we will ask our technical team to further confirm the cause and follow up on the issue. Thank you again for your patience and cooperation, and we look forward to your reply.
