Picar-x with RPI5, camera too dark
Hi all
I was building the Picar-x-v20 using a Raspberry Pi 4, and all was working great until I wanted to start using more demanding modules like Visison Ai stuff, etc.
So I got hold of a Raspberry Pi 5 with 8GB RAM, and a fan HAT to sit between the RPI5 and the SF Robot HAT. Again, all seems to be working fine BUT the output form the camera is VERY dark compared to when using it with the RPI4.
Is anyone else having this problem or can advise how to improve the lighting in the video?
My camera is very dark on the Raspberry Pi 4. Any luck with a solution? How is the Rpi 5 doing with the AI stuff?
The camera image appears quite dark. We recommend providing a photo of the issue for us to confirm.
It is also advisable to operate in a well-lit environment.
Please also check if the camera cable is properly connected.
I had the same issue with mine. I just purchased the version 2 camera and it worked much better.
i just reread your message, if it is worse than when running on the pi4 a new camera might not be the fix.
