I’ve managed to get everything working on my Picar X up until Section 17 - Ollama
When I try the 2. Test Ollama section , I get this error:
Hello, I am a helpful assistant. How can I help you?
>>> hello
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 198, in _new_conn
sock = connection.create_connection(
(self.\_dns_host, self.port),
...<2 lines>...
socket_options=self.socket_options,
File “/usr/lib/python3/dist-packages/urllib3/util/connection.py”, line 85, in create_connection
raise err
File “/usr/lib/python3/dist-packages/urllib3/util/connection.py”, line 73, in create_connection
sock.connect**(sa)**
ConnectionRefusedError: [Errno 111] Connection refused
The above exception was the direct cause of the following exception:
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 787, in urlopen
response = self.\_make_request(
conn,
...<10 lines>...
\*\*response_kw,
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 493, in _make_request
conn.request**(**
**method,**
...<6 lines>...
**enforce_content_length=enforce_content_length,**
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 445, in request
self.endheaders**()**
File “/usr/lib/python3.13/http/client.py”, line 1333, in endheaders
self.\_send_output**(message_body, encode_chunked=encode_chunked)**
File “/usr/lib/python3.13/http/client.py”, line 1093, in _send_output
self.send**(msg)**
File “/usr/lib/python3.13/http/client.py”, line 1037, in send
self.connect**()**
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 276, in connect
self.sock = self.\_new_conn**()**
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 213, in _new_conn
raise NewConnectionError(
self, f"Failed to establish a new connection: {e}"
) from e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f7006dbe0>: Failed to establish a new connection: [Errno 111] Connection refused
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 667, in send
resp = conn.urlopen(
method=request.method,
...<9 lines>...
chunked=chunked,
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 841, in urlopen
retries = retries.increment(
method, url, error=new_e, \_pool=self, \_stacktrace=sys.exc_info()\[2\]
File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 519, in increment
**raise MaxRetryError(\_pool, url, reason) from reason** # type: ignore\[arg-type\]
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘192.168.50.20’, port=11434): Max retries exceeded with url: /api/chat (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7f7006dbe0>: Failed to establish a new connection: [Errno 111] Connection refused’))
File “/home/greglchapman/picar-x/example/17.text_vision_talk.py”, line 48, in
response = llm.prompt(input_text, stream=True, image_path=img_path)
File “/usr/local/lib/python3.13/dist-packages/sunfounder_voice_assistant/llm/llm.py”, line 236, in prompt
response = self.chat(stream, \*\*kwargs)
File “/usr/local/lib/python3.13/dist-packages/sunfounder_voice_assistant/llm/llm.py”, line 199, in chat
response = requests.post(self.url, headers=headers, data=json.dumps(data), stream=stream)
File “/usr/lib/python3/dist-packages/requests/api.py”, line 115, in post
return request("post", url, data=data, json=json, \*\*kwargs)
File “/usr/lib/python3/dist-packages/requests/api.py”, line 59, in request
return session.request**(method=method, url=url, \*\*kwargs)**
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 589, in request
resp = self.send(prep, \*\*send_kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, \*\*kwargs)
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 700, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘192.168.50.20’, port=11434): Max retries exceeded with url: /api/chat (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7f7006dbe0>: Failed to establish a new connection: [Errno 111] Connection refused’))
What’s going on?
