For Picar-x Raspberry PI 5
I assembled the car ok, but, there are a few issues.
When I image a new storage card with the latest Picobricks code, the card will not boot.
When I try the Sunfounder app, it will not connect. I have verified that both are on the same network and I can even connect via SSH on my phone. When I add the code and run the example, I get the following errors:
~/picar-x/example $ sudo python3 13.app_control.py
vilib 0.3.8 launching …
picamera2 0.3.22
websocket server start at port 8765
File “/home/daryl/picar-x/example/13.app_control.py”, line 19, in
px = Picarx()
File “/usr/local/lib/python3.11/dist-packages/picarx-2.0.3-py3.11.egg/picarx/picarx.py”, line 48, in init
self.config_flie = fileDB(config, 777, os.getlogin())
OSError: [Errno 6] No such device or address
I don’t know the product nor anything about the code that comes along with it but I noticed a potential typo in your code.
Not sure if this was a copy/paste error or not but ….
self.config_flie shouldn’t that be file instead?
omg! never saw that!. And,when I go to edit the file, it has a lot of references that use flie. Will take a while to fix.
This is a big fail on Sunfounder. And I have to wonder, what else is wrong. They need to first fix their documents.
What system are you currently using, and what version is it?
Did you encounter any errors while installing all the library code? If so, please provide a screenshot of the error to help us analyze and resolve the issue.
All modules installed just fine, no errors encountered
Here is my system; output of uname -a Linux darylpi 6.6.51+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
Also note, some of the examples work just fine, like moving etc. However, the camera isn’t working;
sudo python3 7.display.py
picamera2 0.3.22
Local display failed, because there is no gui.
Web display on:Exception in thread vilib:
File “/usr/lib/python3.11/threading.py”, line 1038, in _bootstrap_inner
self.run()
File “/usr/lib/python3.11/threading.py”, line 975, in run
self._target(*self._args, **self._kwargs)
File “/usr/local/lib/python3.11/dist-packages/vilib-0.3.8-py3.11.egg/vilib/vilib.py”, line 229, in camera
picam2 = Picamera2()
File “/usr/lib/python3/dist-packages/picamera2/picamera2.py”, line 257, in init
camera_num = self.global_camera_info()[camera_num][‘Num’]
IndexError: list index out of range
[http://10.1.10.193:9000/mjpg](http://10.1.10.193:9000/mjpg)
Starting web streaming ...
Input key to call the function!
q: Take photo
1: Color detect : red
2: Color detect : orange
3: Color detect : yellow
4: Color detect : green
5: Color detect : blue
6: Color detect : purple
0: Switch off Color detect
r: Scan the QR code
f: Switch ON/OFF face detect
s: Display detected object information
* Serving Flask app 'vilib.vilib'
* Debug mode: off
File "/home/daryl/picar-x/example/[7.display.py](http://7.display.py)", line 134, in <module>
main()
File "/home/daryl/picar-x/example/[7.display.py](http://7.display.py)", line 98, in main
take_photo()
File "/home/daryl/picar-x/example/[7.display.py](http://7.display.py)", line 60, in take_photo
Vilib.take_photo(name, path)
File "/usr/local/lib/python3.11/dist-packages/vilib-0.3.8-py3.11.egg/vilib/vilib.py", line 415, in take_photo
status = cv2.imwrite(path + '/' + photo_name +'.jpg', Vilib.img)
cv2.error: OpenCV(4.10.0) :-1: error: (-5:Bad argument) in function 'imwrite'
[new branch] multiPool → origin/multiPool
Already up to date.
~/vilib $ libcamera-hello
[0:03:02.891092671] [2284] INFO Camera camera_manager.cpp:325 libcamera v0.3.2+ 27-7330f29b
[0:03:02.898670264] [2290] INFO RPI pisp.cpp:695 libpisp version v1.0.7 28196ed 6edcf 29-08-2024 (16:33:32)
[0:03:02.915931716] [2290] INFO RPI pisp.cpp:1154 Registered camera /base/axi/p cie@120000/rp1/i2c@80000/ov5647@36 to CFE device /dev/media2 and ISP device /dev /media0 using PiSP variant BCM2712_C0
Preview window unavailable
Stream configuration adjusted
[0:03:02.917480541] [2284] INFO Camera camera.cpp:1197 configuring streams: (0) 1296x972-YUV420 (1) 1296x972-GBRG_PISP_COMP1
[0:03:02.917608919] [2290] INFO RPI pisp.cpp:1450 Sensor: /base/axi/pcie@120000 /rp1/i2c@80000/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selec ted CFE format: 1296x972-PC1g #0 (0.00 fps) exp 33222.00 ag 7.56 dg 1.06 #1 (30.01 fps) exp 33222.00 ag 7.62 dg 1.05 #2 (30.00 fps) exp 33222.00 ag 7.62 dg 1.05 #3 (30.01 fps) exp 33222.00 ag 7.81 dg 1.02 #4 (30.01 fps) exp 33222.00 ag 7.81 dg 1.02 #5 (30.01 fps) exp 33222.00 ag 7.88 dg 1.02 #6 (30.01 fps) exp 33222.00 ag 7.94 dg 1.01 #7 (30.01 fps) exp 33222.00 ag 8.00 dg 1.00 #8 (30.01 fps) exp 33222.00 ag 8.00 dg 1.00 #9 (30.01 fps) exp 33222.00 ag 8.00 dg 1.00 #10 (30.01 fps) exp 33222.00 ag 8.00 dg 1.00
#141 (30.02 fps) exp 33222.00 ag 8.00 dg 1.00
This camera test code worked and produced an image within VNC;
from picamera2 import Picamera2, Preview
camera_config = picam2.create_preview_configuration()
picam2.configure(camera_config)
picam2.start_preview(Preview.QTGL)
picam2.start()
time.sleep(2)
picam2.capture_file(“test.jpg”)
So, with the fixes to the typos in picarx.py the camera is now working.
However, the Sunfounder App for Android (Galaxy s23) won’t connect. Both are on the same LAN and I can connect to the Raspberry PI via an SSH app on the phone.
Not sure how, but, I can successfully connect to the app.
However, there is no ‘Picar-x’ applet. So, I don’t know what widgets to add and their values.
I did try the other car applet, but, got this error;
picamera2 0.3.22
ip : 10.1.10.193
Debug mode: off
stop and exit
camera close
File “/home/daryl/picar-x/example/13.app_control.py”, line 207, in
main()
File “/home/daryl/picar-x/example/13.app_control.py”, line 183, in main
pan = min(90, max(-90, Joystick_Q_Val[0]))
After successfully connecting to the app, click on “Create Remote.” In the presets section, you can swipe to the right to see the PiCar-X preset templates. Just click on “Use” to proceed.
Greetings, I think i am having the same troubles here. Everything went smoothly, i thought, until i tried the camera example, then received the same types of errors. Did these typos get fixed? I am a bit of a novice, but I did try editing picarx.py. Before I figure out permission issues and what’s next, I wanted to just see if this fix had been resolved or carefully documented somewhere else.
If you ran the example code and received an error, it would be helpful if you could provide a screenshot of the complete error message. This will assist us in analyzing the problem and finding a solution for you.
Our Picar-X product’s tutorials and code have been updated and upgraded.
We recommend that you install the latest Raspberry Pi OS, then follow the tutorial steps to install all library code, and finally run the APP example to see how it works.
Starting web streaming …
client (0, ‘192.168.1.14’) conneted
Serving Flask app ‘vilib.vilib’
Debug mode: off
stop and exit
File “/home/kienchen/picar-x/example/12.app_control.py”, line 221, in
main()
File “/home/kienchen/picar-x/example/12.app_control.py”, line 191, in main
TypeError: ‘int’ object is not subscriptable
We conducted testing and verification, and the APP example can run normally.
We recommend checking if the Wi-Fi network is functioning properly. We suggest restarting the system and then running the APP example again to see how it works.
If possible, we also recommend trying a different Wi-Fi network to check its performance.
Regarding the install libhdf5-130 … Error issue?
We have already fixed it. Please update the vilib library and then install it again. Use the commands below:
cd vilib
git pull
After all libraries are successfully installed, run the example code again to see how it works.
