I assembled the PICAR-X and it works when connected to my PC
When the Picar is first connected to my PC, I get
“You are now connected to “SHAW2557” IP 10.0.0.110”
I then disconnect the Picar from my PC.
However, when I try to connect the app Sunfounder Controller to the Picar, I get “Connection failed”.
On the controller, I press “SCAN”, no results.
I press “Manual”, and enter the device IP, and press “Connect”, I get “Connection failed”
What am I doing wrong, and what am I missing?
Please follow the steps in the tutorial link:
https://docs.sunfounder.com/projects/picar-x-v20/en/latest/python/control_by_app.html
Note: The WiFi that your mobile cellular device and picar-x are connected to should be in the same LAN for the connection to work properly.
If there is no automatic search, you can also manually enter the IP to connect.
If possible, we suggest you provide us with a video of the operation process, so that we can help you analyze and solve the problem.
I installed all the modules and trying to run the app controller but getting this error.
Could you please advise?
from sunfounder_controller import SunFounderController
ModuleNotFoundError: No module named ‘sunfounder_controller’
Did you do this bit?
cd ~
git clone https://github.com/sunfounder/sunfounder-controller.git
cd ~/sunfounder-controller
sudo python3 setup.py install
Spf650 is correct.
Please follow the tutorial steps:
