Hi All
Using a Pi5 8gb, Set everything up, but unable to connect to the app, when trying to install the final part ;
sudo python3 13.app_control.py
It comes up with the error ;
“IndexError: list index out of range”
Full code below after running; sudo python3 13.app_control.py
vilib 0.3.16 launching …
picamera2 0.3.25
File “/home/admin/picar-x/example/13.app_control.py”, line 4, in
from vilib import Vilib
File “/usr/local/lib/python3.11/dist-packages/vilib/init.py”, line 2, in
from .vilib import Vilib
File “/usr/local/lib/python3.11/dist-packages/vilib/vilib.py”, line 182, in
class Vilib(object):
File “/usr/local/lib/python3.11/dist-packages/vilib/vilib.py”, line 184, in Vilib
picam2 = Picamera2()
File “/usr/lib/python3/dist-packages/picamera2/picamera2.py”, line 257, in init
camera_num = self.global_camera_info()[camera_num][‘Num’]
Any ideas? Have tried 32bit and 64bit raspberry pi OS and installed and reinstalled all required modules. Have also tried the latest image with ezblock pre installed - sound works with this os fails with all others, and connects to ezblock but ezblock doesnt work at all
Thanks in advance
