Hi, on my pico-4wd the rear-right wheel isn’t working probably, or at all.
Running the test_motor.py from the github repo only spins the other three wheels…
Switching around the Motor between the connectors shows the Motor itself is fine .. rear right is turning on Motor 3 Port for example.
I measured GP10 and GP11 from the PicoPi and they both seem to output 1V. I believe only one should output Voltage depending on the direction, right?
I only have a multimeter to probe around so I’m not quite sure my assessment of the problem is correct so maybe someone has another idea
and can help me fix it.
Thanks for the help.
kind regards
