I switched the Pidog off and disconnected it from all cables.
When I connect it now with power, but the PI itself switched OFF, it makes a loud noise.
When I switch the PI ON, the noise is gone.
At first I thought that it is a loud servo, but the only servo connected was not moving and the PI was switched off in anyway. - It sounds like loud white noise.
The only idea I can come up is the loudspeaker or something in connection with loading the battery.
But why? I have no clue.
Please provide us with a video of the issue you are facing. This will help us analyze and resolve the problem more effectively.
1.Please check the voltage of the battery and ensure that it is able to charge properly.
2.We suggest reinstalling the Raspberry Pi system and then attempting to boot up the Raspberry Pi again to see if the issue persists.
3.Once it has successfully booted up, please follow the steps in the tutorial to install all the required library codes. You can find the tutorial here: https://docs.sunfounder.com/projects/pidog/en/latest/python/python_start/install_all_modules.html
If the installation of the i2samp.sh script is failing, I would recommend trying to install it a few more times, and then rebooting your Raspberry Pi. And then running the sound example code and observing how it performs.Any video recordings of the issue occurring would also be very valuable.
The I2C address signal is normal.
Please check if the wiring of the ultrasonic sensor is correct and consistent.
When running the example, did you encounter any errors? Please provide a screenshot of the print output after running the example, so that we can analyze and help you solve the problem.
