Do somebody know how connect the pidog on a iphone without router
Have you try to make a wifi access point on your iPhone and connect your pidog to it? But I’m not sure if you can control it after…
Yes, that’s correct. You can enable the WiFi hotspot on your phone, and then connect the PiDog to the WiFi network created by your phone. Later, if you want to connect using the app, you can do so as well, since the PiDog will be on the same local network as your phone.
