But just now I powered on the Pironman with just an nvme, and no sdcard. I got a screen saying I could decide to install something for a second. Then the display went blank, and since I already had an OS on the sdcard, I powered down and inserted my Raspberry Pi 5 sdcard with Raspberry Pi OS (Debian 12).
Now I get no screen no matter what I try, not on HDMI 0 nor on HDMI 1, but it does boot from the sdcard and I can get to a shell over ssh. I installed the software from pironman.git (branch v2.0) and now the other stuff just works - fans, small display… just no HDMI!
Any tips on what I can do to try and get HDMI to work again? I hope I don’t have to disassemble everything just to try the onboard micro-hdmi.
Decided to disassemble and the direct connection with the Pi does give me HDMI. But when I assemble back the hdmi adapter … just no display at all. I think my HDMI adapter is dead. Everything works, the nvme, the tiny display… but no HDMI.
I don’t know if anyone will believe me, but I thought this part (the HDMI adapter) smelled funny (burned) when I took it from the anti static plastic wrapping. Just this part, the others are ok.
This is the 2nd batch of Pironman 5, I was one of the people who immediately pre-ordered when the first batch got sold out. Received it today, assembled it and then this happened.
Uploading a video so I can show you just what’s going on.
For HDMI output, the issue seems to be an hardware problem with USB HDMI Adapter, for that you need to contact consumer service at service@sunfounder.com
Thanks @Weirdguy. I checked: jumpers on or not on the board, doesn’t make a difference: no activity in the RGBs.
I did edit the eeprom but I don’t think it affects the LEDs. However, when I turn the Pironman off, the green LED stays on and green. Is it supposed to do that?
pironman ~ # systemctl status pironman.service
● pironman.service - pironman service
Loaded: loaded (/lib/systemd/system/pironman.service; enabled; preset: enabled)
Active: active (running) since Sun 2024-06-30 13:27:40 CEST; 5min ago
I can change the rgb_style to static or whatever: no change. Just no leds. I tried different pin numbers just to be sure.
I mailed sunfounder service, we’ll get it sorted I’m sure. They’re really helpful on the forums.
I see you didn’t install the good software for the case. Normaly for pironman 5, you need to enter this command : sudo pironman5 -c. So you need to remove pironman with those commands : sudo pip3 uninstall pironman sudo rm -rf pironman
and install pironman5 with this tutorial: Pironman 5 - NVMe M.2 SSD PCIe Mini PC Case for Raspberry Pi 5 — SunFounder Pironman documentation cd ~ git clone https://github.com/sunfounder/pironman5.git cd ~/pironman5 sudo python3 install.py
When you turn off the rpi5, those LEDs stay on, it’s normal.
Ohh did I really install the wrong software? good catch.
So, to uninstall, I tried both pip3 uninstall pironman and /usr/local/bin/pip uninstall pironman but I’m getting this:
# sudo /usr/local/bin/pip uninstall pironman
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
For more information visit http://rptl.io/venv
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Should I use --break-system-packages? Sorry, I have never worked with Python much
I saw in your previous videos that you have install nvme, be sure to follow tutorial step by step to configure it correctly. I means the good tutorial for Pironman5
LOL yes indeed. But I will have to wait before I can use it: the NVME did work, but it uses the 5V pins from the HDMI adapter and unfortunately I just can’t get the output to work.
If it works with different HDMI cable, I hope the board is ok even with a “funny smell”
After fully assembly, make sure to configure nvme as tutorial, enable it into boot\firmware\config, copy the OS from SD card to nvme and change boot order into Sudo rpi-eeprom-config --edit bootorder=416 and reboot.
I am also facing issue with HDMI Port, both the HDMI port is not working. However, when I tried to connect to Micro-HDMI port using Raspberry Pi Micro-HDMI to HDMI cable, the display comes up fine. What should I do.
In my case the HDMI cable turned out to be faulty – with the same issues: it worked with the micro-HDMI converter cable, but when I took out the converter, it would no longer work. Which is unexpected. So, try a different cable first.
